FI ECU fuse blew
112,000 MILES • 1.7L • 4 CYL • FWD • AUTOMATIC
DUANEO
  • 6 POSTS
ECU what other circuits run off it?
Apr 4, 2016 at 3:48 AM
HMAC300
  • 48,601 POSTS
if it's fuse 1 inside car it runs the ignition coils.
Apr 4, 2016 at 5:14 AM
DUANEO
  • 6 POSTS
The fuse that has blew is the one under the hood and I tired a new fuse and it blew. Was wondering what else runs off the ECU circuit?Do you have any idea where I should look to find a short that could be causing this fuse to blow?
Apr 4, 2016 at 7:54 AM
HMAC300
  • 48,601 POSTS
fuse 6 which is the one that blows goes to the items in pic the yellow blk wires go to pcm so it may be a connection problem or maybe a relay
Apr 4, 2016 at 8:45 AM
