The fuel pump is located inside the fuel tank. To access the pump, you will have to remove the rear seats.
Also, this vehicle does not have a traditional fuel pump relay, the fuel pump is controlled by a module. Located in the trunk.
I have attached fuel pump and module instructions below. Please note that there are few different options for the module and the pump set up for this S60.
