2000 Ferrari Modena Bad Alternator?
2000 FERRARI MODENA
20,000 MILES • V8 • 2WD • AUTOMATIC
INGPR
every time I push my gas pedal five lights on my instrument panel turn on at the same time. These lights are ABS + ASR + Brake + Transmision + battery blinking. Also when this happens my speed radar reads "hi volt", my radio turns off and a strange noise is coming from the battery area which is located at the foot rest on the passenger seat.
I did the battery test ant it was ok. I did the test with the meter with the engine running and the read was 14.4 V which is acceptable.
Do my alternator has something to do with this?
Feb 5, 2010 at 8:42 AM
2CARPRO JACK
  • 11,533 POSTS
Sounds like it. Have you had the meter on it when everything is lit up with voltage warnings? What about if you bring the rpms up a little?
Feb 5, 2010 at 11:46 PM
