1975 Ferrari 308 engine blowby
1975 FERRARI 308
9,841 MILES • V8 • 2WD • MANUAL
DOM35
i have compression and i have fire
the car still bachkire through the carbs and blowby
what is my problem
Apr 9, 2009 at 2:56 AM
JACKDO
  • 12 POSTS
Back firing is most likely caused by the ignition timing being retarded. What do you mean by "Blowby?
I think you mean lots of blue smoke from the tail pipes?
If that is the case then with so few miles on the engine I would suspect some worn valve guides caused by burning unleaded fuel in an older leaded fuel engine.
Provide some more details if you have not solved your problem.
Apr 14, 2009 at 9:01 PM
JERRYGOODWRENCH
  • 77 POSTS
check the pcv and ign timing .
Apr 18, 2009 at 11:12 AM
DR LOOT
  • 2,311 POSTS
most likely what you are experiencing is the carburetors are flooding, that would cause excessive smoke from the tailpipe due to the fact that you are burning all the oil that is lubricating the cylinders, that is why the smoke is blue. I can come repair the vehicle but you will have to buy me around the ticket and expenses it will be cheaper than taking it to a shop
Jul 20, 2010 at 7:15 PM
DOM35
you asked me if car for sale yes 30000 for the car
and no i did not hot rod it
Jul 20, 2010 at 9:19 PM
DR LOOT
  • 2,311 POSTS
were you able to repair the vehicle? where are you located? send me some photos to davidgedo@gmail.com
Jul 21, 2010 at 4:59 AM
