1975 Ferrari 308
1975 FERRARI 308
DOM35
Engine Mechanical problem
1975 Ferrari 308 V8 Two Wheel Drive Manual
the blowby i am getting is thru my air pipe that goes to my carbs
the car misfire oil straight to my valve covers
extremely high pressure to the valve covers
engine was rebuilt 4 years ago did not drive the car to often maybe stuck ring
or oil pump that is driven by belt
Apr 15, 2009 at 1:31 PM
  • 31,937 POSTS
Hi there,
This blow by will be a ring problem, engine compression is by passing rings and over pressurizing the sump causing this problem, you should be able to identify the problem cylinder/s with a leak down test or a wet & dry comp test.
Mark (mhpautos)
Apr 15, 2009 at 4:25 PM
DR LOOT
  • 2,311 POSTS
mhpautos is correct most likely we are not getting the whole story here sounds like you took it out and hot rod it and ruined it, do you want to sell it?
Jul 20, 2010 at 7:23 PM
DOM35
yea i want to sell
Jul 20, 2010 at 9:23 PM
