UN-JEWG YOUR BATTERY
INSTALL FULLY CHARGED OR NEW BATTERY...IT DON'T MATTER.
INSURE CHARGING SYSTEM WORKS....A POPULAR AUTO PARTS STORE WILL DO IT FOR FREE MOST OF THE TIME
YOUR "POSSIBLE" "RUN DOWN" BATTERY MADE THE COMPUTER GO HAYWIRE......LIGHT ON, DOOR OPEN.....MAYBE A PARASITIC DRAW
MAYBE "JUMPING" YOUR RIG, FIRED YOU UP.......MADE IT GO............
BUT.......MR. COMPUTER IS STILL HAYWIRE, FROM THE VOLTAGE DROP INITIALLY..........IT IS STILL RECOGNIZING LOW VOLTAGE!
UN-JEWG-ING MR. BATTERY COMPLETELY AND MAYBE ......A.......10 MINUTE WAIT, SHOULD RESET MR. COMPUTER................BUT WAIT!!!
............LET'S GET THE BATTERY TESTED AT A POPULAR AUTO PARTS STORE!......THIS IS USUALLY A FREE SERVICE!
THEN INSTALL A "FULLY CHARGED" BATTERY (YOUR OLD ONE MAY BE OK--CHARGE IT)........CHARGE THE OLD BATTERY 1OO% OR IF IT'S BAD INSTALL A NEW ONE
BEFORE YOU HOOK IT BACK UP IN THE VEHICLE!
THEN IMMEDIATELY OFF TO THE PARTS STORE---FOR MORE TESTING!
........THIS TIME HAVE THE ALTERNATOR TESTED....WHILE IT'S STILL IN THE VEHICLE!...AND THE VEHICLE WILL STILL RUN
THIS IS A TEST YOU CAN DO AT HOME, TO SEE IF THE ALTERNATOR'S CHARGE REACHES THE BATTERY.........THIS MAY BE A BAD ALTERNATOR OR JUST A PROBLEM IN THE CIRCUIT (FUSE, FUSIBLE LINK, BAD CONNECTION)...........HOWEVER, THIS IS NOT A LOAD TEST, LIKE AT THE AUTO PARTS STORE
http://www.youtube.com/watch?v=Bzz7P3qNHcE
BAD CONNECTIONS...EVEN AT THE BATTERY MAY BE THE PROBLEM
SEE THIS LINK
https://www.2carpros.com/questions/1996-chevrolet-tahoe-wont-start-sounds-dead-battery-jumpbox-get-same-reults
WE ALSO NEED TO REMEMBER........A BATTERY, AN ALTERNATOR, OR "ANY" AUTO PART CAN BE BAD........RIGHT FROM THE "GIT-GO!"......OR CAN "GO BAD" AT IN ANY LENGTH OF TIME!
LET ME KNOW WHAT YOU FIND
THIS MAY HELP IF YOU NEED A NEW BATTERY OR ALTERNATOR
https://www.2carpros.com/questions/2001-dodge-neon-milage-just-want-put-fliuds-their-locations
THE MEDIC
Apr 15, 2013 at 10:09 AM
