Login
Join
Ask a Question
Questions by Vehicle
Repair Topics
Testing / Diagnostics
Repair & Service Guides
Symptoms
Warning Lights
Trouble Codes
How It Works
Videos
Login
Become a Member
Home
Buick
Century
Engine
Symptoms
Not Running
Cranks will not start
1991 BUICK CENTURY
130,000 MILES • 3.3L • 6 CYL • 2WD • AUTOMATIC
NETO AVILA
MEMBER
1 POST
wont start. cranks but won't turn over. i checked noise from fuel pump it there. i did tune up. got half tank gas.
Jan 18, 2021 at 8:52 AM
Experienced Mechanic
This sounds like a fuel issue so we need to start from the basics by checking the pressure. Here is a guide that will help with this:
Just because you hear the pump does not mean that the pump is creating the needed pressure.
If the pump checks out then here are two guides that will get us through the next steps:
https://youtu.be/dCjmRL3p4Cs
Let us know what you find with this and we can go from there but let me know what the pressure is first and foremost. Thanks
Jan 18, 2021 at 9:44 AM
Add image or video
Ask a new question
Engine won't start
Engine stalls while driving
