My vehicle has been slightly underpowered lately. I noticed the air filter was nasty so I replaced it, and I also cleaned the MAF sensor and cleaned the throttle body. It seemed okay for a day but then the low idle and lack of power returned. I can hear what sounds like a vacuum leak now. I checked as many lines as I could find and all seem fine. But the two lines that connect to the purge valve are vibrating pretty roughly and none of the other lines are. Even as you trace the hoses from the vent to where they connect, the further from the vent you go, the less you feel the vibration. Is this normal or is the valve faulty? I don't have any meters or anything like that to test the valve so I was wondering if the excessive vibration was a sign it was no good. Thanks!
Mar 1, 2021 at 3:32 AM
