Faulty oil switch
2010 NISSAN SENTRA
145,000 MILES • 2.5L • 4 CYL • 2WD • MANUAL
TVISSIA
Just wondering if a faulty oil switch would cause a no start as my oil light turned on? It has oil. It cranks now but will not start.
Nov 28, 2017 at 1:25 PM
  • CAR REPAIR CONTRIBUTOR
  • 31,937 POSTS
I doubt it, but to be sure you can ground out the oil switch wire, this will indicate full oil pressure and the light will go out. if it does start, you will have an oil alert system fitted which has shut down the engine, if so replace the switch, start here.
Nov 28, 2017 at 1:52 PM
