Number 4 injector has failed?
46,300 MILES • 1.5L • TURBO • 2WD • MANUAL
GUMBOSEV
Number 4 injector has failed. Is it okay to just replace the faulty one or should I have all 4 replaced or have the remaining 3 tested?
Sep 27, 2024 at 2:47 AM
  • 55,711 POSTS
At only 46,000 I would just replace the one it must have been weak from the factory unless you have had a fuel contamination problem, then I would do all 4. Let us know if you need anything else.
Sep 27, 2024 at 6:20 AM
