Faulty fuel gauge
128,000 MILES
CAR4ME
  • 7 POSTS
I can fill my car up with gas and the gauge will not go past half tank and the hand jumps around. Already had both sending units replaced .
It will go to full but will not show empty or lower than half of tank.
Please help me.
Dec 5, 2016 at 4:53 AM
  • 31,937 POSTS
It sounds as if the sender has been damaged when installed, if it is going to full, the electrical side is sound, but the sensor is not going to full low deflection with a low fuel load, i feel that this is where the problem is, start here.
Dec 10, 2016 at 7:07 AM
CAR4ME
  • 7 POSTS
Thanks so much for the answer to my question . So what's next ? Buying both sending units again . Or just the one unit ? Someone said it could be the. Mcluster so hope it isn't cause it is a high item to buy . So glad u ruled that out . Thanks slot. May God bless u for ur help
Dec 10, 2016 at 7:42 PM
  • 31,937 POSTS
If you earth the wire that goes to the sender the gauge should go from empty to full, this is the best way to prove the cluster gauge is ok.
Dec 11, 2016 at 4:33 AM
