Faulty gauge
128,780 MILES
CAR4ME
  • 7 POSTS
It is S sedan not sure about the other . The car has two sending units on each side located in car under back seat . A mechanic did it . If I lift up the back seat they are two on both sides . He replaces both. Hope this helps . Thanks!
Dec 11, 2016 at 6:54 PM
HMAC300
  • 48,601 POSTS
this can be a CAN BUS problem a mechanic will have to use his scanner to check it it could also be a bad gauge which cluster would need to be rebuilt.
Dec 11, 2016 at 11:50 PM
