Faulty Air suspension?
55,000 MILES
TROYBONE
Hello, I have an aftermarket air suspension installed on my Toyota Hilux truck. The issue I am having is when I press the button to put air in the bags, front and back, the air drops or depletes from the system like it would if I was pressing the actual buttons to lower the truck. This just started happening after a tropical storm so I'm not sure if that had anything to do with it.
Jun 1, 2023 at 9:53 PM
  • 55,658 POSTS
It sounds like the compressor stopped working can you hear it kick on when you hit the switch? I would check the fuses and the power and ground to the compressor motor.
Jun 2, 2023 at 2:42 AM
TROYBONE
Hello Ken,
I ended up finding the issue by inspecting the air tank under the truck. There was a plastic air line connector that was brittle and broke off at the connection point. I found a replacement at the hardware store and installed it. Truck is allowing air to fill the bags and holding air!
-Troy
Jun 3, 2023 at 9:02 PM
  • 55,658 POSTS
Glad you could get it fixed, thanks for letting us know. Please use 2CarPros anytime we are here to help.
Jun 5, 2023 at 2:23 AM
