Fault codes
117,000 MILES • 1.5L • 4 CYL • FWD • AUTOMATIC
SKILLIN
My car started running rough it if nowhere the other day. The code reader reads c1201, c1224, and p0302. What should I look to for troubleshooting?
Jan 2, 2016 at 9:14 AM
WRENCHTECH
  • 20,760 POSTS
The "C" codes are chassis codes so they have nothing to do with engine performance. The P0302 indicates a misfire in cylinder #2. You will have to determine what the cause of the misfire is through diagnosis.
Jan 2, 2016 at 11:18 PM
SKILLIN
Yes, I can tell it's misfiring. The c codes break to ecu malfunction and ne circuit open or short. I'm not sure what I need to do to narrow down the faulty part to repair it.
Jan 2, 2016 at 11:24 PM
WRENCHTECH
  • 20,760 POSTS
As I said, you don't need to be concerned with the C codes right now. The ABS module has lost communication with the PCM but that doesn't effect engine performance. Concentrate on the misfire. Start out looking at the ignition system ie; Plugs, coils, wires, etc
Jan 2, 2016 at 11:30 PM
