Fault code p2294
116,000 MILES • 1.6L • 4 CYL • 2WD • MANUAL
ANDY71
Car lost power and stopped. coolant had drained. fixed leak now car will not start. Says I have problem with fuel pressure regulator two control circuit. Can you help?
Mar 23, 2018 at 5:51 AM
  • 55,691 POSTS
When you had the coolant leak did the engine overheat? If so does the engine sound normal when cranking it over? Can you shoot a quick video of the engine cranking so I can see what is going on?
Best, Ken
Mar 26, 2018 at 2:42 AM
ANDY71
no, car never overheated. it does sounds normal, I am unable to send video at the moment as I have disconnected several parts off the engine/fuel pipe. have bought new ECT sensor. just wondering how fault code read the control circuit, is it possible that steam got into wire connections?
Mar 26, 2018 at 5:30 AM
  • 55,691 POSTS
Okay good, I would say the fuel pressure regulator is having a problem but the wiring diagrams do not show a fuel pressure regulator?
It shows mechanical diagrams below. Is the stats on the car right ? year make model also diesel or euro car?
Mar 26, 2018 at 12:40 PM
