Fault codes P0722 and P0850, where is the Output Speed Sensor located?
2009 CHEVROLET CAPTIVA
12,000 MILES • 2.4L • 4 CYL • 2WD • AUTOMATIC
FRANCIS TOLENTINO
Does anybody know the output speed sensor's location and the Park/neutral switch input circuit? Thank you in advance.
Aug 18, 2022 at 3:02 AM
  • 55,423 POSTS
The output speed sensor or VSS is located inside the left side pan so that will need to be removed. Here is the location and how to change the sensor out in the images below. They call the park neutral switch a mode sensor. Check out the diagrams (below). Please let us know what happens.
Aug 18, 2022 at 6:41 AM
FRANCIS TOLENTINO
Thank you!
Aug 18, 2022 at 6:49 PM
  • 55,423 POSTS
Use 2CarPros anytime, we are here to help. Please tell a friend.
Aug 19, 2022 at 4:34 AM
