Fault Code 49472 and 01305
34,836 MILES • 1.4L • 4 CYL • 2WD • AUTOMATIC
MB-POWER
  • 80 POSTS
This car have check engine light on, after scanned we found a lot of fault codes. : ( 49472 ,00112, 00849, 00769, 00772 ,04874 and 01305.
All fault codes has been cleared. Only two codes (49472 and 01305) not accept clear.
your advice please.
Thanks
for more details :
code 49472 : lost communication with control module.
code 01305 : databus infotainment-no signal/communication
All fuses has been checked and found okay.
Regards
Nov 4, 2017 at 12:54 AM
MB-POWER
  • 80 POSTS
now (check engine light is off) but the two codes ( 49472 & 01305) still there!
Nov 4, 2017 at 4:00 PM
MB-POWER
  • 80 POSTS
Good morning.
Any advice or help please.
thanks
Nov 5, 2017 at 2:30 PM
STEVE W.
  • 15,374 POSTS
VAG vehicles always seem to have codes that trigger off one event and just stay there.
See if you can pull up the freeze frame data for each code, you want to look at the number of times the event was triggered and if it coincides with a low voltage event. They are both codes that can be set by a loose connection to the stereo system or if it has an after market audio system.
Nov 6, 2017 at 6:32 AM
