Fault code 2E82
134,555 MILES • 2.3L • 6 CYL • 2WD • AUTOMATIC
MB-POWER
  • 80 POSTS
Cooling fan of this car is on with high speed all the time!
After scanned we found following code : 2E82 .
Also, what is the meaning of ( radiator shutter )?
Need help please.
Thanks
Nov 7, 2017 at 4:47 PM
  • 31,937 POSTS
That code is for a failed coolant pump, with no circulation it looks as if the fan defaults to high speed. the radiator shutter is a set of shutter blades that open and close for more or less air flow as demanded by the cooling system, it all controlled via the on board management system.
Nov 7, 2017 at 5:27 PM
MB-POWER
  • 80 POSTS
Good morning
water pump has been replaced and it's okay now.
thanks for every body.
Nov 15, 2017 at 2:55 PM
  • 55,616 POSTS
Good to hear, please use 2CarPros anytime we are here to help.
Cheers, Ken
Nov 18, 2017 at 6:56 AM
