Fault code #1 bank, #2 oxygen sensor heater.
2004 MITSUBISHI ENDEAVOR
130,000 MILES • 6 CYL • 2WD • AUTOMATIC
MLCOOPER
I have replaced all 4 oxygen sensors and still have the same fault code. I can reset the computer and light will go off. Start the car and run it a few minutes and turn it off, the check engine light comes back on next time the ignition is turned on with the same fault code, #1 bank, #2 oxygen sensor. Any ideas?
Feb 16, 2014 at 1:43 AM
HMAC300
  • 48,601 POSTS
check for an air leak and if code is 420 or 430 it's aconverter not O2 sensor. could be short in wiring as well
Feb 16, 2014 at 2:36 AM
HOMER1967
  • 875 POSTS
are there any exhaust leaks near that 02? or even before it. and exactly what code are you getting? please post the code up here for us to see.
Feb 16, 2014 at 3:32 AM
MLCOOPER
Fault code is P0141, #1 bank, #2 oxygen sensor heater.
Feb 16, 2014 at 3:39 AM
HOMER1967
  • 875 POSTS
at this point I would say you need to take it to a shop to have it diagnosed,you have to do some testing at the sensor itself ,you need to test for battery voltage,ground,voltage to the heater ,and reference voltage.it could be a pcm,oe ecm issue which would require a replacement part or a re-flash.but I couldn't find any tsb's on it.also check all of the fuses to make sure that that is not the issue.and again,any exhaust leaks? if so where?
Feb 16, 2014 at 5:43 AM
