The fans are not turning on car temperature sits at 90?
2006 AUDI A3
162,000 MILES • 1.6L • 2WD • MANUAL
RED76
MEMBER
Hi, the fans are not working but I have seen a small switch that's not in place that makes them come on, but I can't find where it goes.
Aug 12, 2022 at 10:26 PM
RED76
MEMBER
Any idea where this goes this triggered the fan when pressed well held down for bit then they come on?
Image (Click to enlarge)
Aug 13, 2022 at 12:03 AM
✓Experienced Mechanic
Yep, that is broken. I can tell where it is from the picture, I guess it is a heat sensor for the radiator? Check the image below to see if this could be the part?
If your about I send another pic looks like there is another sensor there maybe a replacement but still the fans not working, is it still okay to drive for now if not stuck in lengthy traffic?
Aug 13, 2022 at 3:54 AM
I wouldn't, in the summertime the engine can overheat quickly. Dees the radiator cooling fan come on with the A/C? If not, you may have a bad fan motor. Here is a guide to check for power and how the cooling fan system works in the image below. Check the power to the main fan control module (fuse 3, 50-amp fuse panel A).
