Cooling fans and A/C keep running with the key off.
Jan 28, 2019 at 7:22 AM
✓Experienced Mechanic
Good evening,
Does the compressor clutch stay engaged as well or just the blower motor and the cooling fan?
The PCM is what controls the cooling fans. Good chance it may need the PCM replaced.
Are there any codes?
Images (Click to enlarge)
Jan 28, 2019 at 8:36 AM
LARRY1521
MEMBER
No code just cooling fans I unplugged the battery for about 20-30 minute now the fans off but the temperature gauge read a little before normal is that ok
Jan 28, 2019 at 8:55 AM
The gauge should not read anything with the key off.
Jan 28, 2019 at 9:05 AM
LARRY1521
MEMBER
No it reads zero with the key off, but I’m saying when the truck is running it used to read to 210 and now it reads 200. is that fine?
