fan clutch
1994 CHEVROLET SILVERADO
170,000 MILES • 5.7L • V8 • 2WD • MANUAL
CRAIGMCLAIN3855
At what temperature should the fan clutch kick on to cool the radiator?
Jul 2, 2018 at 5:51 AM
DANNY L
  • 5,648 POSTS
Hello, I am Danny.
Unlike an electric fan which is controlled by sensors and the PCM (a vehicles computer)- A fan clutch is a viscous coupler controlled mechanically by the fans RPM's with the engine running. The fan clutch is an item that wears normally and is subject to replacement after time/wear. Is truck running hot? I have attached a tutorial the shows you its function. Hope this helps and feel free to ask questions if needed. Can also include fan clutch replacement instructions if needed. Danny-
https://www.2carpros.com/articles/how-a-clutch-fan-works
Jul 2, 2018 at 11:56 AM
CRAIGMCLAIN3855
The temperature was approximately 225-235°F. It was idling with the A/C on for about ten minutes. The fan had not engaged and it cooled down when driving down the road. I replaced the engine temperature sensor as I thought it controlled the fan clutch. The fan clutch engages on a cold start like it always has. Thank you for the information.
Jul 2, 2018 at 12:04 PM
DANNY L
  • 5,648 POSTS
Hello again.
You are welcome! Glad to help. Thanks for using 2CarPros.
Danny-
Jul 2, 2018 at 12:52 PM
CRAIGMCLAIN3855
How hot should it get before the fan clutch engages? Thanks.
Jul 2, 2018 at 12:54 PM
DANNY L
  • 5,648 POSTS
Hello again.
Normally a viscous fan clutch (mechanical) as yours is usually aiding air flow at lower speeds/idling when there is not as much air flow as there is at high speeds/freeway driving (a lot of air flow). Have you had the fan clutch tested to see if it is operating correctly?
Danny-
Jul 2, 2018 at 1:46 PM
CRAIGMCLAIN3855
No, not yet. I try to do things myself first as I am a broken man on a broken income. If it continues, I will have to take it to a mechanic. Thank you for your help, Craig
Jul 2, 2018 at 2:42 PM
DANNY L
  • 5,648 POSTS
Hello again.
You are welcome Craig. Hope things work out for you and thanks for using 2CarPros. Danny-
Jul 2, 2018 at 3:26 PM
