Replaced oil sensor 9 months ago,second one replaced 3 months ago. Also crank seal replaced due to oil leak. After return from the garage,the fan stayed on when ignition is switched off: small air video screen also stays on.Have only had it checked by competent non-dealer mechanic because of our location : has reset the codes from his computer terminal,but problem still exists,Also cannot lock and unlock the doors with remote control.Other than this,everything seems to work as normal,Alternator replaced last week,battery replaced a month ago.Not much support from Hyundai because we live outside the dealer network.
Aug 9, 2014 at 12:45 AM
