Fan speed not working correctly
175 MILES • 5.4L • V8 • 4WD • AUTOMATIC
DIMITAR STEFANOV GLAVINOV
  • 28 POSTS
As of today, while driving my pickup, suddenly the heating fan started to work only at a high level. The scale of the display, no matter what degree it reads, the heating fan works only at maximum. Let me know where the problem is and which part should be replaced, if any possible and the number of this part. Thanks in advance.
Dec 3, 2020 at 9:06 PM
BMDOUBLE
  • 1,139 POSTS
This sounds like a classic failed blower motor resistor. I have attached the actual test, and if it fails, the replacement procedure.
Dec 4, 2020 at 12:09 AM
  • 28 POSTS
I will check it well (change). Where is this part in the car? If it turns out that the problem is not there, is it possible in this part:
https://www.ebay.com/itm/New-Blower-Control-Switch-Front-E150-Van-E250-E350-F150-Truck-F450-F550-F250/371633950678
Where is it also in the car?
Thanks in advance.
Dec 4, 2020 at 12:24 AM
DANNY L
  • 5,648 POSTS
Hello, I'm Danny.
Here is the information you requested. I've attached a picture below of the location of the blower motor resistor and the Ford factory blower motor resistor part number. The resistor is located near the right hand kick panel. Hope this helps and thanks for using 2CarPros.
Dec 4, 2020 at 3:08 PM
  • 28 POSTS
Thank you for the information but in my situation the resistor turned out to be a whole resistor module (part number is 4L3H19E624AA). The bad thing is that this part is not for sale, so it had to be repaired. In general, there are two burned out transistors. are no longer produced need to be renewed with their replacements which are also with better parameters. I forgot to note that this part is found only in one place in eBay used, but I chose to repair mine (https: // www. ebay.com/itm/07-FORD-F150-TEMPERATURE-CONTROL-MODULE-4L3H19E624AA/154091937088?autorefresh=true). About the repair I recommend a specialist who repairs audio, video and television equipment.
Dec 29, 2020 at 11:21 PM
DANNY L
  • 5,648 POSTS
Hello again.
Glad to hear you were able to solve the problem and thank you for sharing. This will possibly help someone in the future with the same problem Thanks again for using 2CarPros and we hope you will use our site again in the future. Happy Holidays.
Danny-
Dec 30, 2020 at 7:48 AM
