It's in my way, trying to get the serpentine belt back on, after I changed the alternator on my truck. Thanks, TT04
12/13/2021.
Dec 12, 2021 at 3:58 PM
✓Experienced Mechanic
Good morning,
The shroud needs to be installed. If you leave it out, the truck could overheat because the draw of cool air from in front of the radiator will be very low. Only hot air in the engine compartment will be left to cool the motor and it will cause it to run hot.
