Fan on radiator does not turn on
150 MILES • 1.1L • 4 CYL • MANUAL
METALHEAD1
Pipes from radiator builds up pressure but fan don't switch on. Only when sensor is disconnected. Changed sensor and relay but still don't work. Works when AC is switched on.
Dec 13, 2019 at 4:03 AM
This is a control module issue. Here in the USA we call it a PCM but it may be an ECM (engine control module) overseas. When the sensor is disconnected it is giving the module an open circuit so the default is to turn the fan on. Also, when the AC is on the default is to turn it on. If everything is hooked up and the sensor is reading accurately, as we can assume it is since it has been replaced, then more than likely the control module is the issue.
Dec 14, 2019 at 8:12 AM
