Fan not working
120,000 MILES • 4 CYL • AUTOMATIC
MELODI VANBRUNT
  • 7 POSTS
I have replaced coolant sensor and relay, fan still did not come on.So I used a wire to jump the sensor plug wire so the fan would come on when I turn the ignition key on then off when I turn the ignition key off.The fan would work then.
Nov 21, 2019 at 1:16 AM
  • 110,248 POSTS
If the fan will run, it's good. Also, since the relay was already replaced with the same results, that isn't the issue. I can tell you that if the relay is is getting power, then I expect the problem is between the ECM and the relay. The ECM is what signals the fan on.
Nov 21, 2019 at 9:25 AM
