I would say the relay is bad for one thing, check ground on left hand frame rail as well then check to see if new relay is making good contact with wires at connection it may be a PCM problem so see if a mechanic can use his scanner to see if that is a problem and command fans on. Check your engine coolant temp switch as well and if you have a/c turn that on and see if fans start. It may be a PCM problem.
SPONSORED LINKS
Monday, March 20th, 2017 AT 7:29 AM
