Fan like sound when i accelerate after being in traffic
25,000 MILES • 2.5L • 4 CYL • TURBO • RWD • AUTOMATIC
JOSHUAUSEN
  • 5 POSTS
When I am using my car specially while in traffic or hot weather, there is a fan like sound when I am accelerating. But after a couple of seconds of pressing the gas pedal to 2000 rpm the "fan like sound" disappears, and it goes back again after a traffic or in a traffic light.
I read your article about intake tube and I think it is possible that is the problem.
Jul 24, 2017 at 5:41 PM
HARRY P
  • 2,292 POSTS
There is no 2015 Mitsubishi Montero. A 2005 Montero does not have a four cylinder engine either. So my information may be wrong, as I guessed that you had a 2005 Montero with a V6 engine (the only engine available).
I am betting that the sound you are hearing is like a combination of a roaring and whooshing sound. Probably your cooling fan clutch is slipping a little bit.
With the engine off and cold, turn the cooling fan by hand. It should have some resistance, but still turn. If it turns freely or lightly, then the clutch has failed and needs replacing. Check it and let us know.
Jul 24, 2017 at 8:57 PM
RENEE L
  • 1,260 POSTS
Hi JOSHUAUSEN,
I found these links on the site I think will help you with your car's issue.
https://www.2carpros.com/articles/how-a-clutch-fan-works
https://www.2carpros.com/articles/fan-clutch-removal
https://www.2carpros.com/articles/fan-clutch-symptoms
If you need further assistance please feel free to come back to 2CarPros as we are here to help.
Have great rest of your day!
Kindest regards,
Renee
Admin
Jul 25, 2017 at 9:31 AM
HARRY P
  • 2,292 POSTS
Thanks Renee. I meant to post to those articles but ran out of time this morning.
Jul 25, 2017 at 11:58 AM
RENEE L
  • 1,260 POSTS
Hi HEYMAN1104,
No worries we are all part of the team. Keep up the great work!
Renee
Jul 25, 2017 at 12:37 PM
JOSHUAUSEN
  • 5 POSTS
I live in the Philippines and there is a Montero 2015 here.
But anyway i will check my fan according to what you said, I only experience this in traffic and in hot weather but my engine is not overheating,
Thanks for your reply.
Jul 25, 2017 at 1:14 PM
JOSHUAUSEN
  • 5 POSTS
Thanks Heyman1104 and Renee.
Jul 25, 2017 at 1:15 PM
HARRY P
  • 2,292 POSTS
Ah, that explains why I cannot look it up. Still, look and see if you have a hydraulic clutch fan. I am betting that you do and that the clutch is slipping a little bit when it is hot. My truck does the same thing. Personally, I would not worry about it unless it starts running hot.
Jul 25, 2017 at 1:26 PM
JOSHUAUSEN
  • 5 POSTS
Hi Heyman 1104
Yeah I will check it.
Thanks, this sites is very useful!
Jul 25, 2017 at 1:29 PM
JOSHUAUSEN
  • 5 POSTS
Hi heyman1104 and renee
I checked my fan blade and turn it and it has resistance but it turn, I think my fan clutch is ok. Hmmm,
My other guess is the intake tube. But i checked and it was ok.
Jul 26, 2017 at 3:58 AM
HARRY P
  • 2,292 POSTS
I still bet it's the fan clutch. I honestly cannot think of anything else that fits the symptoms that you're describing. You might be able to take out your thermostat, which would cause the engine to run cooler. If it makes the sound less often with no thermostat, then that would confirm a slipping fan clutch. Unfortunately I have no access to specifics about your truck, so I can't tell you how to do that.
Jul 26, 2017 at 7:25 AM
