fan clutch removal
215,515 MILES • 5.4L • V8 • 2WD • AUTOMATIC
ANDDOR10
  • 8 POSTS
what size tool needed?
May 14, 2022 at 9:18 PM
SQM
  • 6,383 POSTS
To remove the fan clutch you will need a special fan clutch removal tool.
It takes two special wrenches to loosen the clutch. They are 36mm and 57mm.
Most auto parts stores have those tools that you can use to complete the task.
Here is a helpful guide:
https://www.2carpros.com/articles/fan-clutch-removal
I have attached some pictures below for your reference.
Let me know of any questions.
May 15, 2022 at 2:00 AM
ANDDOR10
  • 8 POSTS
Thanks Sean, this has helped me a lot.
You guys are fantastic.
May 15, 2022 at 9:28 AM
SQM
  • 6,383 POSTS
You are welcome!
Thank you for using 2CarPros.
May 15, 2022 at 1:48 PM
