Intermittent fan clutch engagement
180,000 MILES • 4.0L • V6 • 4WD • AUTOMATIC
DMAURER4
Can the fan clutch engagement issue be intermittent if going bad or would it always be engaged if bad or failing?
Sep 15, 2020 at 4:39 AM
  • 110,248 POSTS
It can be intermittent. It can be a fluid issue or an electrical issue since the fan is electrically actuated. The fan clutch has three main elements, a fluid chamber, reservoir chamber, and clutch actuator valve/fan speed sensor. The actuator valve and speed sensor are controlled by the power-train control module.
I attached a pic below. Check to make sure the connection at the actuator is clean and tight.
Also, take a look through this link. It describes common symptoms related to a failing fan clutch.
https://www.2carpros.com/articles/fan-clutch-symptoms
Sep 15, 2020 at 11:04 AM
DMAURER4
Thank you! This was very helpful! Greatly appreciate the help.
Sep 15, 2020 at 10:15 PM
  • 110,248 POSTS
You are very welcome. Please feel free to come back anytime in the future if you have questions or need help.
Sep 16, 2020 at 10:16 AM
DMAURER4
Thanks! I definitely will!
Sep 16, 2020 at 11:47 AM
