Fan blower resistor
57,000 MILES • 4.0L • 6 CYL • 4WD • AUTOMATIC
RICHPACHECO
Fan blower only works on three and four.
May 1, 2018 at 11:36 AM
  • 110,246 POSTS
The blower motor resister is bad. It is located under the dash on the passenger side of the vehicle. I attached a picture to help locate it. It will be held in with two screws. Simply disconnect the wiring plug, unscrew it, remove, and reverse the order to replace.
May 1, 2018 at 12:06 PM
RICHPACHECO
Do I get to the resistor from inside the vehicle?
May 9, 2018 at 6:16 AM
