Fan belt replacement
105,000 MILES • 4 CYL • 2WD • MANUAL
PAUL HATTINGH
I am struggling with a diagram to replace my fan belt.
The way I think it should be is not the way.
Please please can you help?
Oh, it is a Ford Rodcam 1.6 2007 model
Many thanks.
Paul
May 19, 2018 at 3:36 AM
JIS001
  • 3,412 POSTS
We do not have that vehicle here in the USA but did a little research. It appears as if this engine is the Ztec engine used here in the USA. I found a video you can watch where they show an animated version of how that engine was put together. If you pause the video at the 2:38 time mark, your belt routing will be displayed if this is the correct engine. Here is the link:
https://youtu.be/nsvDcUG_eo4
Check out the video and let us know if it helped you so it may help others in the future as well.
May 20, 2018 at 9:32 AM
