Erratic fan speed
180,000 MILES • 1.6L • 4 CYL • 2WD • MANUAL
KALIMO
The fan run in full speed as if the engine is hot and the heat gauge shooting up to the maximum.
Aug 22, 2017 at 1:37 PM
  • 55,673 POSTS
This sounds like the engine is overheating causing the cooling fan to act funny. Is the cooling system full of coolant?
Here are some guides to help us find the problem:
https://www.2carpros.com/articles/engine-overheating-or-running-hot
and
https://www.2carpros.com/articles/car-is-leaking-coolant
Please let us know what you find.
Cheers, Ken
Aug 23, 2017 at 4:50 AM
STEVE W.
  • 15,398 POSTS
It is also possible the engine coolant temperature sensor is bad and it is causing the PCM to think the engine is hot when it is not. If it does this within say a minute of being started or even setting still and just turning on the key I would check the ECT first.
Aug 23, 2017 at 4:38 PM
