Cooling fan not working?
13,564 MILES • 3.6L • 6 CYL • 4WD • AUTOMATIC
GERALEB
Inoperable fan.
Aug 6, 2022 at 2:23 PM
  • 55,691 POSTS
In the right front fuse panel, there are 2 fuses # 1 - 70 amp and #4 - 70 amp that we need to check. Here is a guide to help and I have found the cooling fan wiring diagrams. If the fuses check out there is a cooling fan control module that sounds like it is not working, here is the location as well:
and
Check out the diagrams (below). Please let us know what you find.
Aug 7, 2022 at 1:55 AM
