Fan not working
245,000 MILES • 1.6L • 4 CYL • 2WD • MANUAL
WILLIAM SIMON MITCHELL
Hi there,
My vehicle listed above bakkie's fan not going on. I have replaced the temperature switch but it still won't work. Please advise.
Oct 25, 2020 at 1:08 AM
  • 110,248 POSTS
This vehicle isn't offered in the US, so my technical information is very limited. However, I will try my best to help.
First, most vehicles will have a designated fuse for the fan motor and one or more fan relays. Have you checked fuses and relays? Here are a couple of links you may find helpful:
Also, if the fuses and relays check good, see if the fan turns on if you run power directly to it.
Let me know what you find.
Oct 25, 2020 at 10:39 AM
