the water pump is leaking
2011 FORD F-150
167,000 MILES • 3.7L • V6 • 4WD • AUTOMATIC
DAWSON CURL
  • 23 POSTS
i noticed my radiator fan comes on more than normal in the last week and it’s
very very loud. now i the water pump is leaking.
Apr 13, 2020 at 5:12 AM
  • 110,240 POSTS
Luckily, this water pump isn't too bad to replace. I can't even begin to tell you how many are driven by the timing belt.
Regardless, here is a link that shows in general how a water pump is replaced:
https://www.2carpros.com/articles/water-pump-replacement
Here are the directions specific to your vehicle. The attached pics correlate with the directions.
_________________________________________________________________
2011 Ford Truck F 150 4WD V6-3.7L
Coolant Pump
Vehicle Engine, Cooling and Exhaust Engine Water Pump Service and Repair Removal and Replacement Coolant Pump
COOLANT PUMP
Coolant Pump - 3.5L GTDI, 3.7L
MaterialItem .................... Specification
Motorcraft(R) Specialty Orange Engine Coolant
VC-3-B (US);
CVC-3-B (Canada) .................... WSS-M97B44-D
pic 1
Item Part Number .................... Description
1 W503291 .................... Coolant pump pulley bolt - 25 Nm (18 lb-ft) (4 required)
2 8A528 .................... Coolant pump pulley
3 W503278 .................... Coolant pump bolt (7 required)
4 8501 .................... Coolant pump
5 8507 .................... Coolant pump gasket (part of 8501)
6 8565 .................... Coolant pump O-ring seal (part of 8501)
Removal
1. Remove the air cleaner outlet pipe.
2. Loosen the 4 coolant pump pulley bolts.
3. Remove the accessory drive belt.
4. NOTICE: Cover the A/C compressor belt to prevent coolant contamination of the belt.
Completely cover the A/C compressor belt with waterproof plastic.
5. Remove the thermostat housing. For additional information, refer to Thermostat Housing 3.5L GTDI or Thermostat Housing 3.7L.
6. Remove the 4 bolts and the coolant pump pulley.
7. Remove the 7 bolts and the coolant pump.
Remove and discard the gasket and the O-ring seal in the coolant pump.
Installation
1. Install a new O-ring seal in the coolant pump and lubricate it with clean engine coolant.
2. Position a new gasket, press the coolant pump over the channel cover plate snout protruding from the engine front cover and install the 7 bolts finger tight.
3. Tighten the coolant pump bolts in the sequence shown in 2 stages.
Stage 1: Tighten to 10 Nm (89 lb-in).
Stage 2: Tighten an additional 45 degrees.
pic 2
4. Position the coolant pump pulley and install the 4 bolts finger tight.
5. Install the thermostat housing. For additional information, refer to Thermostat Housing 3.5L GTDI or Thermostat Housing 3.7L.
6. Remove the plastic from the A/C compressor belt.
7. Install the accessory drive belt.
8. Tighten the 4 coolant pump pulley bolts.
Tighten to 25 Nm (18 lb-ft).
9. Install the air cleaner outlet pipe.
10. Fill and bleed the cooling system. For additional information, refer to Cooling System Draining, Filling and Bleeding.
If you haven't already, this is a good time to replace the thermostat and flush the radiator and engine block.
https://www.2carpros.com/articles/coolant-flush-and-refill-all-cars
I don't know if you want them, but here are the directions specific to your vehicle for the thermostat.
Thermostat
Vehicle Engine, Cooling and Exhaust Cooling System Thermostat Service and Repair Removal and Replacement Thermostat
THERMOSTAT
Thermostat - 3.7L
pic 3
pic 4
pic 5
Removal and Installation
1. Drain the cooling system. For additional information, refer to Cooling System Draining, Filling and Bleeding See: Cooling System > Procedures > Cooling System Draining, Filling and Bleeding.
2. Remove the air cleaner outlet pipe. For additional information, refer to Intake Air Distribution and Filtering See: Air Cleaner Housing > Exploded Views > Intake Air System Components - Exploded View.
3. NOTICE: Cover the accessory drive belts to prevent coolant contamination of the belts.
Completely cover the accessory drive belts with waterproof plastic.
4. If installing a new coolant inlet connector, release the clamp and disconnect the lower radiator hose.
5. Remove the bolts and the coolant inlet connector.
- To install, tighten the bolts to 10 Nm (89 lb-in).
6. Remove the thermostat and the thermostat O-ring seal.
- Discard the O-ring seal.
7. To install, reverse the removal procedure.
- Use a new O-ring seal and lubricate it with clean engine coolant.
8. Fill and bleed the cooling system. For additional information, refer to Cooling System Draining, Filling and Bleeding See: Cooling System > Procedures > Cooling System Draining, Filling and Bleeding.
Make sure to inspect radiator hoses and heater hoses. If they need replaced, do it when everything is drained from the system.
I hope this is helpful. Let us know if you have other questions.
May 7, 2021 at 4:16 AM
