False overheating warning light turning on?
100,000 MILES • 6 CYL • AUTOMATIC
JYOUNG37766
The warning light is coming on saying that it is overheating, however it is cool to the touch and there is no steam or anything of that nature. I just replaced the thermostat and the spark plugs.
Sep 3, 2022 at 6:01 AM
  • 55,694 POSTS
Yep, it sounds like the engine coolant temperature sensor is stuck at the upper range. here is the coolant sensor location so you can sway it out, let me know how things go. Check out the diagrams (below). Please let us know what you find. I left location for both the 3.6 and 3.4.
Sep 3, 2022 at 9:19 AM
JYOUNG37766
We replaced the ECT tonight and at first it was doing good so I drove it to the gas station and for some reason it did it again.
Sep 3, 2022 at 4:47 PM
  • 55,694 POSTS
You could have a defective thermostat, which brand did you use? I always use OEM parts, FYI. To confirm, remove the thermostat and drop it in a pan of boiling water to see if it opens.
Sep 5, 2022 at 2:15 AM
