My car is a diesel. It will not start. I have used a jump cables and the power box cables and it still will not start. What can this be?
Dec 19, 2017 at 7:58 PM
✓Experienced Mechanic
When you say will no start I assume it will not turn over. It sounds like the battery is so bad that even a jump start will not help which is normal when this happened.
Here are guides to help us run a simple test to confirm the failure:
