would not start at all it just clicked
174,894 MILES • 2.5L • 4 CYL • 2WD • AUTOMATIC
DONSTAFFORD
Everything has been fine with my car until about a two weeks ago when it failed to start on my way home with groceries and just kept hitting the button until it did start (weakly too). The next day it would not start at all it just clicked. So I thought the starter locked up but I I removed that had it tested and got a new battery and neither fixed it. I then noticed a little key/locked car logo on the left side of the instrument cluster inside the rpm gauge. Changed key fobs and batteries in them also done nothing. The steering wheel will not lock either. Every time I try to start it just does nothing acc power and everything kicks on but no start.
Mar 1, 2019 at 10:00 AM
SCGRANTURISMO
  • 4,897 POSTS
This could be a loose or corroded connection to the bush button switch. I have included for you in the diagrams below a step by step troubleshooting flowchart for you to go through. Please get back to us with what you find out.
Thanks,
Alex
2CarPros
May 17, 2021 at 11:40 AM
