Failure to start
94,000 MILES • 1.6L • 4 CYL • FWD • MANUAL
BRIAN TURNER2
Engine turns over no problem, but no current to coils and no current to fuel pump. The fuel gauge is functioning, same relay used on both. Relay changed, but problem still exists Can I bypass it to make pump work? I wonder if these two things are related in that they are both needed for engine starting?
May 25, 2016 at 12:01 PM
  • 55,781 POSTS
Hey BRIAN,
I would not bypass the relay, please check for voltage at the relay to see if it is trigger problem or a power source problem, I believe if the crankshaft angle sensor is bad the computer will not turn the system on because it does not see engine rotation.
Here is a guide on how to use a test light and how to replace a cks
and
Let me know what you find.
Best, Ken
May 25, 2016 at 12:16 PM
