fails to start,codes scanner p0321 and p0036
206,000 MILES • 2.0L • 4 CYL • FWD • MANUAL
CALERO
engine light on,car-key light on, replaced starter and battery,spark plugs gap 1.1 mm,replaced sensor crankshaft already and still codes on P0321 -P0036, what else should I do to resurrect this car?
Jun 24, 2015 at 10:12 PM
  • 31,937 POSTS
The P0321 code is triggered when the Engine Control Module (ECM) detects the signal is out of range.
Possible symptoms
- Engine Light ON (or Service Engine Soon Warning Light)
- Lack/Loss of Power
- The engine may be harder to start
- The engine may stumble or stall
P0321 Volkswagen Description
Ignition failure sensor is used to check whether the spark ignition is occurred correctly or not and also used to tachometer drive. The sensor monitors the voltage difference between a resistance which is on the battery circuit for ignition coil. When the ignition coil works properly, the electric current through the resistance is detected as voltage drop. This is confirmed for every ignition event with the crankshaft sensor and the camshaft sensor. If ECM detects a malfunction, no ignition is possible, so the engine would not start. If there is no ignition signal for a predetermined cycle for one or two ignition coils, an ignition coil circuit failure exists.
P0036
- Faulty Heated Oxygen Sensor (H2OS) Bank 1 Sensor 2
- Heated Oxygen Sensor (H2OS) Bank 1 Sensor 2 fuse
- Heated Oxygen Sensor (H2OS) Bank 1 Sensor 2 harness is open or shorted
- Heated Oxygen Sensor (H2OS) Bank 1 Sensor 2 circuit poor electrical connection
- Faulty Engine Control Module (ECM)
The code means that there is a problem with the heater element circuit of the heated oxygen sensor. The control module monitors how long it take the sensor to warm up and start sending an adequate signal. The code is triggered when the sensor is taking too long to warm up. Water getting inside the heated oxygen sensor connector can caused the heated oxygen sensor fuse to blow. Before replacing the sensor, check for the condition of the heated oxygen sensor fuse and connectors. If the sensor and connector are OK, replacing the O2 Sensor 1 usually takes care of the problem
Dec 20, 2016 at 3:17 AM
CALERO
thankyou ,ill try and let you know.
  • 31,937 POSTS
ok, let me know how you get on.
