Center console screen/radio does not come on, interior lights, high beams, and electronic door locks do not work.
Jan 8, 2026 at 6:43 AM
✓Experienced Mechanic
The first thing I would do is check the ECU-B1 fuse which is in the fuse panel under the hood. This fuse runs all of the systems you have motioned, this video will help.
Jan 9, 2026 at 2:10 AM
JLHUBBARD
MEMBER
Awesome, thanks man! I’m going to pull it into the garage this afternoon, and I’ll check it out. Really appreciate the input, I’ll update here on what I find.
Jan 9, 2026 at 2:20 AM
JLHUBBARD
MEMBER
The ECU-B1 is a 10A fuse and it’s good. I replaced it just in case. No luck
Images (Click to enlarge)
Jan 9, 2026 at 8:05 AM
Hmm, Can I ask if this car has the smart key system or not? Ken
Jan 10, 2026 at 1:20 AM
JLHUBBARD
MEMBER
Not sure, I don’t know what that means. It has a fob and I have to touch it to the ignition button to start it. How would I find out?
Jan 10, 2026 at 3:23 AM
Okay, that is the smart key thanks, I would have the car on and test the fuses listed below. Check out the images (below). Please let us know what happens.
