Failing actuator noise?
202,000 MILES • 5.9L • V8 • 4WD • AUTOMATIC
CHRISSY SLONE
I have a blend door actuator going out on passenger side of my vehicle and it makes a ticking noise but now I'm hearing a kind of high-pitched whining noise coming from driver's side. Would this also be an actuator of a different kind, or can the same actuator make a couple of different noises? Or is this not actuator noise at all?
Jul 18, 2023 at 9:12 AM
  • 110,248 POSTS
It is possible that it is a different actuator. Are you experiencing any other issues? For example, can you control the airflow direction? Does the fresh air/recirculate air controller work properly?
Also, here is a link you may find helpful, it explains in general how to replace a blend air door actuator:
Jul 18, 2023 at 2:49 PM
