We have had a new fuel pump,MAF sensor, o2 sensor and new exhaust gaskets on it. What else could be the problem?
May 24, 2016 at 10:39 AM
✓Experienced Mechanic
Most lean mixture codes are caused by a vacuum leak on the engine. That is where I would start. If you have access to a vacuum gauge, place it on any of the intake vacuum ports and start the engine. Vacuum should be around 18 pounds at idle. Also, if you have access to a scanner that can read real time live data, it would be helpful to see what the short term trim readings are. Let me know what you find.
