failed fuel pump
180,000 MILES • AUTOMATIC
PAUL MORELL
  • 5 POSTS
can here fuel pump,but no fuel coming to engine,,do i have to drop fuel tank to get to pump?
Jan 7, 2016 at 11:24 PM
WRENCHTECH
  • 20,758 POSTS
I can't find any info on it but I would look under the back seat and in the truck for a removable cover.
Jan 8, 2016 at 1:40 AM
HMAC300
  • 48,601 POSTS
No there is an access cover under rear seat. see pic for instructions.
Jan 8, 2016 at 1:42 AM
WRENCHTECH
  • 20,758 POSTS
Thanks HMAC300, Alldata didn't have anything.
Jan 8, 2016 at 3:01 AM
HMAC300
  • 48,601 POSTS
I got lucky wrench lol
Jan 8, 2016 at 4:05 AM
PAUL MORELL
  • 5 POSTS
thanks, went ahead and pulled rear seat,,yes thier is a access plate,,,not fuel pump its good,,,fuse good but no is no voltage at plug to fuel pump
Jan 8, 2016 at 5:02 AM
PAUL MORELL
  • 5 POSTS
i think i found relay,seams to be good too,,,
Jan 8, 2016 at 5:05 AM
WRENCHTECH
  • 20,758 POSTS
I hope you realize there will only be power there during cranking.
Jan 8, 2016 at 5:11 AM
HMAC300
  • 48,601 POSTS
then check for a shorted/cut wire leading to pump it's a blk yellow wire also check ground wire. the fuel pump relay is behind lh kick panel. check fuses 17& 32 for power to relay
Jan 8, 2016 at 5:13 AM
PAUL MORELL
  • 5 POSTS
i think i checked that,going to check again
Jan 8, 2016 at 5:23 AM
PAUL MORELL
  • 5 POSTS
thanks,think i found problem,,daughtwer had tranmission done and thier teck put seat covers on for my daughter and when he installed rear seat back he pinched that blk and yellow wire and cut it,,,,thanks for your help
Jan 8, 2016 at 5:35 AM
