failed fuel delivery?
150,000 MILES • 6.8L • V10 • 2WD • AUTOMATIC
SPRINTER78
Tire repair service truck came in on a hook customer stated they had fixed it but not good enough to run more than 40 MPH and then it shut off on them while going to a service call. fuel rail pressure wouldn't go above 9.7 lbs disconnected fuel line from fuel filter on tank side, no fuel would come out. blew air into line acts as if its dead headed. removed tank end of line not blocked it appears someone has replaced the fuel line connectors on tank with some from another vehicle. I would like to start with a diagram of lines and wiring. oh, yeah, i almost forgot with fuel filter line unhooked it runs but with only 9lbs of fuel PSI on rail.
Mar 27, 2025 at 2:41 AM
  • 55,594 POSTS
You can't blow backwards into the fuel line FYI; the fuel pump will stop it. It sounds like the fuel pump has gone bad or they have water in the tank. Here is a link to the repair manual you need for the fuel line diagrams:
https://my.alldata.com/
Please upload pictures or videos in your response of any problems so we can see what to help you with.
Mar 27, 2025 at 5:24 AM
