Factory security
800,000 MILES • AWD • AUTOMATIC
SEJ9571
  • 7 POSTS
I had my factory security disconnected because it kept messing up and I was getting hot here on one side and air conditioning blown out on the other side. so I unhooked my battery to reset it and now the truck wont start.
Aug 10, 2016 at 7:49 AM
SEJ9571
  • 7 POSTS
80,000 miles.
Aug 10, 2016 at 7:50 AM
SEJ9571
  • 7 POSTS
It is a Silverado SS.
Aug 10, 2016 at 7:57 AM
WRENCHTECH
  • 20,758 POSTS
Disconnected security? What exactly did you disconnect because there is no way to disable the immobilizer.
Aug 10, 2016 at 9:20 AM
SEJ9571
  • 7 POSTS
I do not know because the truck would not start sometimes until the key was on the accessory position for ten minutes. And a friend said he could disconnect it. It ran okay for a day then started blowing hot air on one side and my air conditioner on the other side. I was told to unhook battery to reset it and now it wont start. I think the factory security is on all the time.
Aug 10, 2016 at 11:58 PM
WRENCHTECH
  • 20,758 POSTS
You can try a relearn but if it works, it may only be temporary because there is likely a problem with the key sensor that would require a new ignition lock.
PASSLOCK TEN MINUTE RELEARN
AUTO LEARN
Time required, approximately ten minutes:
1. Insure that the battery is fully charged.
2. Use the scan tool in order to clear the DTCs.
3. Turn the ignition switch from the OFF position to the CRANK position attempting to start the vehicle. The vehicle will start and then stall.
4. Leave the ignition switch in the ON position while observing the security indicator.
5. When the security indicator turns off, which can take up to ten minutes, turn the ignition switch off. Wait ten seconds.
6. The BCM and the PCM will learn the new code on the next start attempt.
Aug 11, 2016 at 12:01 AM
SEJ9571
  • 7 POSTS
Will try this and let you know if it works.
Aug 11, 2016 at 12:35 AM
SEJ9571
  • 7 POSTS
Do not have a scan tool I have to take it to someone who does.
Aug 11, 2016 at 6:14 AM
WRENCHTECH
  • 20,758 POSTS
That is only to clear the codes. You can do the relearn without clearing them.
Aug 11, 2016 at 6:21 AM
SEJ9571
  • 7 POSTS
Okay.
Aug 11, 2016 at 6:25 AM
