My car will not crank over, and I found the F15 Transmission Fuse 30amp keeps blowing when the TCM is plugged into transmission. Please help.
Jul 28, 2023 at 11:52 AM
✓Experienced Mechanic
It sounds like one of the clutch actuators has shorted out, most people just replace both, but you can try one at a time, to be sure you can remove the wiring connectors and replace the fuse to see if it blows. Here is how the job is done. Make sure to lube the pivots and slides the best you can. Check out the images (below). Please let us know how it goes.
Images (Click to enlarge)
Jul 29, 2023 at 6:36 AM
JR PAYNE
MEMBER
Hello, thanks for the quick response. I did as you instructed me to do. Everything tested okay. And wasn't getting that direct short any longer. Once I plugged the top actuator connector back in it immediately blew the fuse. What should be my next move on this focus?
Jul 31, 2023 at 8:21 AM
Nice work, I have seen these cars have problems with the clutch system which is very common. I would try removing the clutch actuators and replacing them with new units, but it could be the dual clutch system has come apart and the actuators cannot move the throw-out bearing lever forks which will give you the same result. Make sure to lube the shafts and pivots the best you can while the actuators are removed.
Aug 1, 2023 at 3:03 AM
JR PAYNE
MEMBER
Should my car still start with these disconnected? Because it won't crank over.
Aug 1, 2023 at 3:16 AM
Will it crank with them connected? If so, then I guess not.
Aug 2, 2023 at 11:29 AM
JR PAYNE
MEMBER
No, it wasn't cranking before I removed the connectors either.
Aug 2, 2023 at 1:03 PM
JR PAYNE
MEMBER
Because it kept blowing that #15 fuse.
Aug 2, 2023 at 1:04 PM
Let's install a breaker bar on the front of the engine to see if the engine can be turned over by hand.
Aug 3, 2023 at 3:21 AM
JR PAYNE
MEMBER
Okay, I'll go give it a try.
Aug 3, 2023 at 5:25 AM
JR PAYNE
MEMBER
I replaced the actuator and it's no longer blowing the transmission fuse. I also tried to turn the engine over with breaker bar and by installing a jumper wire in the fuse location and engine is free and cranks over no problem. I also noticed on my dash now when I shift the transmission it now reads the desired gear normally before it wouldn't show you that. Unfortunately, the car still will not crank over with the key please help.
Oct 1, 2023 at 1:43 AM
Let's start a new post for the starter nonoperation please. We only handle one problem per thread and i sounds like we solve the one problem, please post your new question here, you must be logged in.
