What tools do I need to remove a front motor mount bolt?
195,000 MILES • 2.3L • 4 CYL • 2WD • AUTOMATIC
LIONELL8732
  • 150 POSTS
hello i need some help in figuring out what tools will i need to extract this broken off front motor mount bolt without this.. this is making the whole motor mount slides... moves up and down and just having the engine lifting crazy.
Sep 16, 2023 at 2:13 PM
  • 55,710 POSTS
Yep, I would remove the mount before starting to work on it, here is a video to show you how to remove the bolt and which tools to use:
https://youtu.be/py-rIWATchY?si=QWROPLbi1caqhCCk
This is for an exhausts manifold, but the process is the same. Let us know what happens and please upload pictures or videos of the problem so we can see what's going on.
Sep 18, 2023 at 4:58 AM
